A New Project..Again
968
Beneteau 352 Hull #276 Ontario
I've been looking around at the various bilge pump options for my boat (It has a manual switch pump) and I didn't like what I found. So I decided to build a better mouse trap.:naughty:
The Bilge control is based around an Arduino. This is a self contained, cheap ($25), microprocessor. http://www.arduino.cc/
I added an expansion board ($13) and an RTC (real time clock) ($7).
The bilge level is detected by a Differential Pressure Transducer ($11)
Since the bilge in a 352 is as big as my fist and occupied with the electric pump and hand pump suction lines, there is no room for a conventional switch.
This unit detects a change in pressure when water is added to the bilge.
I can select at what level the pump comes on, how fast it comes on and how long after the bilge is empty that the pump continues to run.
I can also log how many times the pump turns on and at what time.
The next step is to add (already ordered) the cell phone option.
http://www.geekonfire.com/index.php?main_page=product_info&cPath=7_49&products_id=78
I will then have the option for the bilge pump to call home in the event of a major problem. You could also tie in other boat information, security, to the unit and send that home via a text message.
All this for under a 100 bucks
I love gadgets:D
Ps: Update: Added Cell phone attachment and tested. works great and easy to program (C++ Language) As I said before you can monitor the security of your boat, ie Battery condition, Hatches open, Bilge condition etc etc.
redege
Jun 29, 2012
19
beneteau oceanis 351 queensland
wow.. impressive set up! I don't know where you get all this stuff from or what some of these are, but if it works..! I have a bene 351 (similar to 352 I think) and might do something like this in the future. Cheers and thanks!
