3 bladed prop
Switch to a 3 bladed prop. I did, and the boat runs at hull speed at just under 3000 rpm, cruises at 6 knots at 2800. The engine also seems to run smoother, and backs 100% better.Check out the February (?) and March issues of Sail magazine on props, particularly three bladed props. A three bladed prop more than doubles the surface area and thrust.I was told that I would loose about .5 knots sailing, and a 5 degrees pointing, but I haven't noticed any difference. Of course I don't race either.Cost was about $300, plus a ten minute haul out to replace the prop. Any good prop shop can give you the proper size, or you can use the Sail article, which has tables and formulas. E-mail me if you want more info.
