Hello everyone. I now the owner of a 1973 Venture 2-22. I'm moving up from an Oday 17 daysailer, which I still have.
This evening after I got home I backed the trailer away from trees and power lines and tried to set up the mast and check my standing rigging.
There was one pleasant surprise. After reading through this and other forums and articles about the Venture 22 before buying, I had visions of building a contraption to raise the mast, but I found that I can easily stand it up myself without any extra rigging involved.
Anyway, I have a feeling that the owners manual that came with the boat is either for a different year, or there have been quite a few modifications to my boat, or probably both.
The first issue I ran into is that when I have the backstay turnbuckle let out as far as it will go, the mast still seems to have a pronounced lean to the rear. My Oday didn't have a backstay so maybe I'm worrying over nothing, but when I look through the boat from the side, the plane of the mast slopes dramatically rearward compared to the profile of the supporting post in the cabin. I attempted to take some pictures, which came out rather washed up but here is one anyway. Does the mast look normal to you folks who have these boats?
My next issue is the boom. I don't know if it's been modified or if this is a completely different boom. The fittings on each end look nothing like the drawings in my manual. The fitting on this end is actually a springloaded square piece of metal which pulls away from the boom and then swivels. I'm guessing this is for furling the sail, (something else I couldn't do on my Oday) but that isn't how the manual describes furling.
The other end has a freely swiveling piece with a hole in each end. It's hard to see in the photo but one hole has a shackle and block attached to it.
Also, the attachments for the main sheet, which I believe were on each rear corner according to my research, are gone. There is a traveler installed across the cockpit against the cabin wall. It's semi hidden by the ratchet strap across the boat but it's easy to see where it is.
I do not see how the main sheet attaches to the boom. It has the car for the traveler but the boom has nothing which makes sense to me as an attachment point. There is a light duty traveler on the bottom of the boom here, which looks just like the jib sheet travelers in my Oday, but the pin is too close to the boom to allow the mainsheet to attach.
The interior is in decent shape, but eventually I intend to gut it and build it in for overnight trips for my wife and I. I haven't even tried to check the running rigging yet, but there are blocks at the base of the mast which seem to be set up for running the halyards back to the cockpit. Curiously there are three blocks on the deck, but only the two for the main and jib on the mast I don't know what the third is for. There is also a cable attached next to the backstay on the mast head with a block on the lower end. I'm guessing this is an added toppping lift which uses the block at the end of the boom.
This should be an interesting project, but I hope to just do enough to sail it this summer, and then to the more extensive work in the winter. After all I also have a project house which I'm completely rebuilding at the same time. But I'm looking forward to building a fancy interior in this boat.
I hope everything here makes sense, I typed most of this with one finger while holding a baby lol. I guess the two real questions I have are, is my mast rigging ok or do I have to modify cable lengths? And, any idea how my mainsheet works with this boom? I'm very confused by that one. And then just any other ideas or thoughts you might have after looking at the photos. This is a more complicated boat than I've ever dealt with and I am open to any thoughts or advice.
Thanks
Thanks
