A Few Maneuvering Tips
Dec 25, 2000
5,951
We have the original 18x15 three blade RH fixed bronze prop on our 1991 P42 and am very pleased with its performance. It will cruise all day long at 1,800 RPM pushing the boat to seven knots. The 4JH2-TE at that RPM burns about one gallon/hr. I normally keep it in neutral while under sail letting the prop spin freely as recommended by Yanmar.
Maneuvering Belle-Vie can be a challenge at times, but it helps to know how your boat behaves under certain conditions. Current and/or wind places considerable pressure on your boat. A tip on docking with the current as opposed to against the current, which is against conventional wisdom.
Pick your docking spot. Bring your boat parallel to that spot and use your engine to slow your boat to a stop. Increase engine reverse speed to offset current drift, then slightly turn the helm towards the dock. Patience is important here.
Drift pressure on the rudder will begin to slowly move the stern towards the dock, while at the same time keeping the bow inline. When the boat touches the dock you can step off and secure the stern line first. At the point you can shut everything down.
I have used this maneuvering technique many times and it has worked every time.
Another tip is departing the dock when the wind is pushing you into the dock. Untie all dock lines except the bow. Place a fender at the bow to protect the boat from the dock. Have a dock hand or deck hand hold the bow line with one wrap around the dock cleat.
Turn the helm hard over to the dock, then increase engine forward speed, which will thrust water pressure against the rudder and push the stern away from the dock. When the stern is far enough away from the dock, the deck/dock hand can release the bow line, the helmsman can quickly turn the helm hard over away from the dock and do a hard reverse thrust to back away from the dock.
It is important to let the deck/dock hand know that it will be difficult to hold the bow line during this maneuver, but it does work. You can do this solo as long as your bow line is long enough for it to wrap around the dock cleat and extend back to the helm.
Another tip is doing a 360 degree turn in a narrow fairway. I have turned our boat on a dime by first turning the helm hard over to starboard and keep it there. Then give a short forward burst of throttle, followed by a reverse burst, then repeat until the boat completes the 360. The combination of forward thrust on the rudder and the prop walk in reverse will turn the boat almost on a dime; a large dime.
Likes: justsomeguy
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
Good Stuff, but if your engine is a Yanmar, I would NOT recommend cruising at 1800 rpm! Those things need to be pushed hard or else you're going to get buildup in the exhaust.
druid
Feb 17, 2006
5,274
I'm sure you meant a 180° turn. Not sure why one would want to do a 360° turn unless they wanted to continue in the same direction.
I have done the prop-walk maneuver to align my bow with the slip with my outboard. Not as effective as an inboard, but it does work.
Dec 25, 2000
5,951
Hi Brian, I did mean 360 degrees, or any degree in between. My point was to say this maneuver does work, at least on our boat.
Feb 17, 2006
5,274
No problem Terry. I have seen a U turn in crowded fairways but haven't seen anyone do a 360 before. It is all good. :)
Dec 25, 2000
5,951
A story about doing 360s. I have a running route by our boat that is three miles out and three back. Often times you will see native Americans walking Reservation Road. One day on my run I ran past an old fellow heading in the same direction, waved with a morning greeting and continued on to my turn around point up ahead. As I was coming back I stopped and commented on the Ravens that were busy cackling in the trees. I agreed with him that Ravens are very smart. Then he asked me if I had forgotten something. I said no, why? He said that usually when someone turns around and heads back where they came from, they have forgotten something. At that we both had a good laughed.
