A few days ago I posted a thread concerning my
Ross
Jun 15, 2004
14,693
Garmin 72 and certain problems I was having with it. The cure for the problems was to disable WAAS. I was a bit concerned about a loss of accuracy but I can tell you that as a result of road testing the loss in accuract is not significant. Drove from home to my slip today and arrived within about 50 feet distance 16 nm. drove home to my driveway and came within 52 feet.
Jun 12, 2004
1,181
Allied Mistress 39 Ketch Kemah,Tx.
Does this mean...
you stopped 52 feet from your driveway and had to ask for directions? Its not like I havent done that before. Tony B
Ross
Jun 15, 2004
14,693
TonyB, At the end of my driveway the gps said I had 120 feet to go
my driveway is 50 feet from the road to the door. When I parked It search for a minute and decided that 52 feet was as close as was needed. If I couldn't take it from there well-------------. ;D
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
50 feet of inaccuracy is a pretty long way in a fog
Or if you happen to be in a foggy state of mind and can't handle the last few feet. Very funny TonyB! I remember (not really) sleeping on a porch of the house next door to my girlfriends one night when in college (back in the dark ages of the late 1970's). I think the people whose porch I slept on were more frightened of me the next morning then I was of them. Since then I steer well clear of the Jack Daniels Shoal even though it does not show up on the GPS.
Ross
Jun 15, 2004
14,693
You guys remember the John Wayne movie
Donovan's reef? Sometimes I run aground in a place like that. Even GPS is no cure for that.
Tim R.
May 27, 2004
3,626
Ross
WAAS will get you down to about 20ft. accuracy which can be significant compared to 50ft. I posted this to your other thread. This update should fix your problems. http://www8.garmin.com/support/download_details.jsp?id=227
Ross
Jun 15, 2004
14,693
TimR,If I understand this I can down load the updates
to my computer and from the computer to the GPS via a data cable. Is that how that will work?
Tim R.
May 27, 2004
3,626
Yes Ross
That is exactly how it will work. It is pretty easy but you can also get Garmin on the phone to assist. They have great tech support.
Ross
Jun 15, 2004
14,693
Tim I agree about their live tech support
The man I talked to last week was finishing my sentences when I discribed the problem I was having. I just ordered the PC- GPS interface cable and I will go from there. Thanks Ross
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Tim R
Thanks for keeping after Ross on this. I updated a friends new 76CSx using their website, and it was easy. Ross, just follow the instructions on the web from Garmin.
Ross
Jun 15, 2004
14,693
I will down load the up dates when I have some
time when I won't be on the computer. (still on dial-up) That will change one of these days Nancy is gettin impatient with the slow speed for the things she wants to so. ;)
Aug 19, 2004
239
Hunter 35 Vancouver, BC
Amazing!
Earlier this week I was following this thread with mild interest because I also have a Garmin 72 that I have used for several years. I made a mental note about the topic in case it ever happened to me. Today I took the boat out for the first time this year and guess what.... a blank screen with a vertical blue line appeared! All fixed tonight as outlined below. My only question. The unit is quite old and the software patch is very new. Is the timing all just total coincidence or is there something that is causing this to happen at the present time?
Ross
Jun 15, 2004
14,693
From the Garmin site it is apparent that there have been several
upgrades since the release of the Garmin GPS 72. This is just the latest. The tech that I talked with said that The problem is from trying to determine which WAAS station(s) to work from and the unit gets into an endless loop. I will post details on the down load when I do it.
Aug 19, 2004
239
Garmin 72 Software Upgrade
This task was very easy.... but you must have the special cable. Just follow the instructions on the Garmin update site. The GPS unit first needs to be placed in Simulator mode and there was one other setting that needed to be checked (forgot which one but I did not have to change anything) and it was all exceedingly smooth.
Jun 11, 2004
1,941
Oday 31 Redondo Beach
waypoints lost with upgrade?
When you do the software upgrade do you lose the waypoints you have stored in the GPS?
Tim R.
May 27, 2004
3,626
You should not
But I would(and do) back them up first.
