Anyone have some guesses on the following? I am having some peculiar issues with my inverter/charger and with my VHF. Both complaining about things that sound like they aren't getting enough power.
A bit of background: the boat is new to us (less that 2 months). It surveyed fine, and everything seemed fine on our sail to our home port after purchase. The house bank is quite old (7 years?). It is comprised of three ~100 amp hour AGMs. If I am interpreting things correctly, they appear to still have some life. After drawing them down 80 amp-hours (based on the Link10 battery monitor), they still show around 12.35V. I have applied a fair amount of load without noticing anything very odd. I have not tried real load testing.
Possibly related to the problems with the charger and VHF: Within the first couple of days after bringing her home, a large lightning storm hit our marina. At least 9 boats on our dock are having most of their electronics replaced.
The only immediate symptom we noticed was our Link10 battery monitor started slowly counting up amp-hours (several hundred amp hours) until I pulled a fuse (I tried resetting it and cycling charger and cursing a bit first). Reconnected the fuse and all seemed OK.
Later discovered the wind gauge no longer worked. Replaced mast-head unit and all is well. All other electronics (with the exception of the inverter/charger and VHF) seem fine.
Now on to the two mystery problems:
The inverter/charger (ProSine 2) gives a "Low Bus Voltage" error and tries repeatedly to restart itself when first connected to shore power. It will not successfully start charging until you use the configuration menu to clear faults. Sometimes it takes 2 or 3 tries to clear the fault. Very rarely it starts with no error. Either way it seems to work fine once it starts. Based on advice from the company, we reseated the connections and measured the voltage at the battery and at the inverter/charger and voltage appears normal, but fault continues to occur. Company says this error is from the DC side of the system. I did not get the error the first (and only) time we plugged in before the storm.
This weekend, I was unable to transmit on the VHF (ICOM IC-M502) with it set to 25 watts. Received "Low Battery" warning on the VHF display every time I pressed the transmit button. Link10 and panel both showed about 12.4V at the time. No large drop in voltage while attempting to transmit. Transmitting on 1watt worked fine. I can't say whether this symptom is new because I have not had reason to use the radio since the storm. (Although I did test it at the dock at some point and it worked fine, but I was hooked up to shore power and charging at the time. It was tested during survey, but I don't remember whether it was at the dock or during the sea trial.) I just tested with the charger off and it worked, but batteries are fully charged at the moment.
So, any useful advice on diagnosing?
Is the ProSine shot, or can it be used in this condition until it fails?
How can I tell if the VHF is really not getting enough power, or whether it is confused (needs repair/replace)?
Am I wrong in believing the batteries have some life left in them? (I know they are getting old.)
If I do need to repair/replace some or all of this, what order? Would it be wise to replace the batteries (assuming they don't load test well) to see if the other things get better? Should I replace the misbehaving charger before investing in new batteries?
