Robin
My water pump for the cruise air ac runs really hot and doesnt completely fill the thru hull with expelled water. Thought it may be a clog in the line so i cleaned the (funky) strainer and checked the lines coming into the pump. I had a hell of a time trying to get it to expell any water and finally had to turn on the fan, disconnect the line to the pump and flush it through with water, almost like a siphon. Is it possible to have a clog past the pump toward the thru hull, or would i benefit from a new pump? As you can imagine, in New Orleans I NEED A/C. The AC works ok now despite this, bringing to mind the ancient law: "dont fix it if it ain't broke..."thanks!
