John K Kudera
Step two was to build and paint a platform to hold the A/C unit under the chart table, that completed and installed, I went to work scoping out the runs of ducts. To A/C the aft cabinI chose to run the duct thru the foreward part of the "wine bottle holder", I intend to run a piece of metal duct there, cover with plywood then foam fill the area. I will run the wire for the thermostat thru there also. And attach the thermostat to the bulkhead, above the opening.At this point we will run the duct foreward in the space behind the cushions, one duct up, one duct down near the mast support bulkhead.The thru hull for the cooling water will be in the small storage locker just inside the aft cabin, low as possible, with the strainer mounted there too, and the pump on the bulkhead under the chart table.The water exit will be in this area also.Part three later, yes I am taking photos!
