A/C in Hunter 37.5 - Generator
May 3, 2011
51
Beneteau & Hunter First 435 & Hunter 37.5 Seabrook & Guntersville AL
I need to add A/C to my Hunter 37.5. How many units do you have of what size and where are they mounted? Where are the water intakes and ball valves located?
Also anyone added a generator, same questions? Thanks
Hunter 37.5 Jacksonville FL
I have installed a 16500 BTU unit under the section of the port setee that buts to the galley. I am using a Mermaid Air with a right discharge. The outflow is just below the bilge discharge. I installed a dedicated thru hull in the vicinity of the engine intake. If you decide to install an I recommend the larger unit. In Florida it takes it all.
