steve rainey
Anyone put a window A/C unit inside the cabin of a sailboat? I don't want to deal with a deck hatch type, and the inboard water cooled type is expensive to buy and also for service calls. I have a area in the salon which has a area that will allow a 500K BTU unit to side into. I plan to set it in a starboard tray and run a drain line to the bilge. Behind this area is a closet which I instend to put a fan in and a vent above thru the deck. Units cost under $100. how can you beat that? Think it will work? I've called a few A/C dealships and they think it would work. Maybe this is being done more than I've heard of? I've heard some say they think I would have a corosion problems. I had window units in use at an appartment building right by the river in Jaxs last 4-5 years or more. The main and only problem I see is being sure its vented enough. Any thoughts?
