Bob Rutland
The cooling water on my A/C unit just barely flows out the side of my boat. I attached a garden hose to the water line leading to the unit(about 40psi city water pressure)to blow it out, and water seem to flow fine. I checked the fresh water strainer and it was clean. After this process of emlimination, I assumed it was the pump. I replaced the pump with a top of the line 380gph Cal Pump.The water still just barely flows. I removed the line leading to the unit and tried to blow through it, but it had alot of back pressure. Is this normal? Could the cooling coil be restricted in some way? If so, how could I clean it? Thanks, Bob
