Cruisair Installation on H260
The Cruiseair unit has worked well for us, even during last summer's heat in southern Delaware. It will keep the boat reasonably cool, but not cold, during a really hot day, but that is when you should be outside having FUN. When the sun goes down, it does a good job, even in the hottest weather. Moving the Cruiseair each time you wish to use it or go sailing can be inconvenient as well as a safety hazard with so many things to trip over on a sailboat. We keep ours on the sea hood under the boom where it does not interfere with anything and where it can be easily removed from the boat, if we wish to do so. To use the unit, we open the companionway hatch all the way and direct the air over the edge into the cabin. I cut two pieces of plywood to fill the hatch opening. One U-shaped piece goes around the edge of the unit and the other fills in the rest of the opening usually covered by the hatch and allows us to easily negotiate the companionway. This arrangement has the added advantage of directing the cool air into the galley and aft sleeping area where we want it the most. The plywood also eliminates the greenhouse effect of the plastic hatch cover and so helps to keep things cooler.Ralph and Connie RegarShambalaLewes, DE
