Grounding
Wow, this topic can get very dangerous.Your ac system needs to be grounded to your dc system, especially if you have an ac charger on the boat.If your ac charger fails there is a potential between the ac and the dc that is a killer. It could run 110 through your 12 volt system. Thus your ac ground should tie your dc system to protect the way grounding is meant to protect. Read a good marine electrical book. There are many out there but I think Nigel Calders' Boat electrical and Mechanical ties it all together. Marine electric is more intense than normal house wiring. You have in conjunction with your ac you have dc , corrosion bonding, and lightning protection and it must all be tied together!!!!!If that charger is not a marine charger keep it off the boat. A regular auto charger is very dangerous on a boat.Sorry for the short sounding response. It is a serious subject. You don't guess when you answer questions that can kill someone.Rick, there is no place in calders book that says to not ground the ac to the dc system. Since I lent mine out I can not steer you to a page but look at some of the diagrams back toward lightning protection and see how all the systems tie together, then reread all the sections on ac, dc, corrosion protection grounding,bonding, and lightning protection. Potentials are a key to all of the above systems.r.w.landau
