Update: Honda 2000 and A/C
I placed pictures and explanations in the Photo forum.I hooked up the 'hard start capacitor' as stated in previous post. Un-hooked the shore power, put the Honda in place and started it up. I put the Honda in full run mode to insure it was running a full blast before turning the A/C on. Forgot to check if it would run in econ mode - another day.Well, we turned on the A/C and after its normal delay, it kicked over. It seemed to be running but Joan was yelling we were getting no water out. I could hear the A/C unit cycling trying to run. The generator did not trip out, which would indicate it had to big of a load and that was encouraging. On the third try, the compressor kicked in and the water pump started squirting water. In a few minutes you could feel the cool air flowing. It just took a couple of cycles to get things running. I imagine you should NOT have a bunch of other things running pulling from the generator at the same time, but there is enough power from the generator to make this work.IT WORKED....JimS/V Java
