Is the boat sitting at the same pitch in the cradle as it does in the water? Is the companion way facing the weather when on the cradle?Is a cockpit drain hose thru hull freezing shut then backfilling thru a bilge pump or something else connected to the same thru hull?When I stripped out the hoses on my Frigate I couldn't believe it hadn't sunk. Cockpit drains were tee'ed into with other brains from pumps and all hoses were rotten.I'd build a framework of 1 X 3 and cover with a tarp for the winter for added protection.
Thanks Capt Spike. Do you think the water is backing up through the cockpit drains into the bilge pump? (Hand type pump). I covered it pretty well last year, but not the cockpit. I will try that this year. Any other thoughts?Bob
