E
ex-admin
What could complicate the simple design of a mainsail? Apparently, a lot. Traditional mainsails typically have a loose-foot or a bolt rope/shelf foot. Some have a cunningham to flatten the sail in a blow. Most have one or more slab reefing points to reduce sail area when need. Then along comes the furling crowd who've figured out how to make a mainsail furl up into the mast -- or the boom. No need for reef points as the whole sail can be reefed. And don't forget those four relatively small battens, which just slipped into pockets along the leech, have also been complicated as some of these designs use no battens, full length battens, or a combination of both. They may even be horizontal or vertical. Some are even adjustable. Some require special hardware on the sail. Are these advances worth it to you?What type of mainsail configuration do you have? Why did you choose it or did you just inherit it with the boat? What do you think its strengths and weakness are? Would you choose the same configuration the next time you buy a mainsail?Tell us about your thoughts on mainsail configurations then take the Quick Quiz on the homepage. (Discussion topic and quiz by Warren Milberg)
