jolie
Dear Head Mistress:Based on what happened to my Hunter 42 Passage, I think the following situation happened. Please give us your opinion.If the joker valve is leaking and the holding tank thru hull is open....Will the passing of holding tank air thru the joker valve then allow sea water to enter the holding tank...Sea water then fills up the holding tank till it overflows back into the head till the incoming holding tank sea water seeks its own level and then stops.Because I do know that the head overflowed - AFTER I pumped out the holding tank - when ONLY the macerator discharge was left open (BEFORE I knew better, Mistress, thank you) and when the joker valve was old, brittle, and had a slightly open mouth.(The head intake thru hull was first closed, but the head overflowed again anyway. So it was definitely the macerator pump out thru hull.)I replaced the joker valve, and all was ok. The discharge thru hull was left open as a trial, and it didnt fill up the head again...so it must have been air leaking out, which allowed sea water to enter the holding tank and fill up the head to sea level.I guess if my head was installed one foot higher, my boat would have been a new coral reef.Whadya think?????I know...CLOSE THAT SEACOCK!!!
