!980 H25 Nose pc
3
Hunter 25 Woodstock, Ga
HI, my nose cap on the bow, is cracked. I thought it was made out of metal, However after investigating and confirming with the guys at Hunter it is made out of fiberglass. They no longer have the molds for the older boats. Has anyone had to repair or replace this piece? Looking at a younger 25 on the next dock, he has a stainless cap over the bow. Any suggestions or ideas?
thanks
tracy
Dec 23, 2003
61
Hunter 36_80-82 Gulfport, MS
On my 82' Hunter 36 the stbd side of the nose was damaged during Hurricane Katrina. The yard took it off and repaired it by glassing in a piece that mirrored the otter side and then painted it like new.
Now that you know it is glass, is it possible to cut the crack in a shallow wide V-groove, glass and eopxy it, sand and repaint? If you have access, you might be able to do it in-place.
Oct 6, 2007
1,172
Hunter H30 1982 Chicago IL
I had the same problem with the bow cap on my '82 H30. Mooring lines, pulling at a more downward angle than dock lines do, cracked the bow cap along lines roughly parallel to the edges (about an 1 1/2" back from the edges) and actually crushed through part of the starboard edge. There were hollow areas under the edges of the bow cap and not really much strength in the cap itself.
My solution was to drill a series of 1/4" diameter holes through the cap about an inch or so apart along the cracks, inject epoxy filler into the hollows, and build up the crushed area with epoxy. Then I routed out the cracks and epoxy filled holes with a Dremel tool, filled them with MarineTex white epoxy putty, sanded and painted it with two coats of matt black Rustoleum. It looks like new and appears to be holding up OK, but the boat is on a dock now, so I haven't really given it the mooring line test yet.
This cap seems to be a common problem area on these boats. I've seen some others replace it with stainless steel...with varied degrees of success. It may be stronger, but it's a complex shape to form, so you need a very good custom fabricator ($$) or it can look kind of crude.
digbysailor
easy
thanks
tracy
easy fix had a crushed cap ont he bow of my 81 25 i removed it took it in the shop and using wod strips i covered them in plastic if i remember correctly then clamped them on the inside of the cap to make a form and glassed and clothed the affected area then sanded and spray painted black looked like brand new.
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
New stemhead fitting for H25
I'm getting a new stem-head fitting for my 1974 H25 which will eliminate the post for the third leg of the pulpit (going to install a different pulpit). photog-- if you want me to have one made for you, with or without the third-leg post, email me :)
