Welcome to the SBO forum. Congrats on your boat selection. Fun ahead.
Maker... perhaps Selden.
Conduit... Possibly.
Wiring connector... You may be able to just pull out a little wire from the fitting at the base. Cut the connector off and install a new connector. Often the wire in the mast is in ok shape. The problem is at the exposed ends and connectors - either the base or at the lights on the mast head. Corrosion is the usual issue. Clean up and or attach new connectors, splash a little corrosion block on the connectors and good to go.
If you are set on dropping the mast, then it would be an opportune time to inspect the standing rigging and all fittings. Refit all fittings, cables and wires, you'll be good go for another 7-10 years.
