No Traveler?
Hmm I am suprised. We have a 1978? H27 with a Traveler located aft of the tiller. Maybe it's an add-on, because if the block is located directly behind the tiller post it will occasionally interfere with operation of the tiller. We generally keep it positioned t oone side or the other, generally on the port side.I can't tell who made the traveler itself, but i can't recommend it because the adjusting cars or slides "pull up" pins broake away, leaving a flat washer with SS flat head shaft (can you say broken fingernails?)But the blocks are Harken and run really well, as long as the lines are kept clear.Bob Es/v Second NatureSalem, MA
