Steve Fehm
I think i've tracked down a leak in my stern cabin to some carriage type bolts that bolt the deck to the hull along the rub rail. The last 4 or so bolts seem to be corroded and lifting away from the rail. It takes several hours of a strong rain for the leak to appear eventually leaking in close to where the port cockpit drain is visible in the stern cabin (by the wood molding). Has any one else had this issue and tried to replace some of these carraige bolts ? or any othe suggestions on where the water might be coming from ?Thanks alot
