86 Legend backstay problem
Mark Walker
Last year we got some pretty heavy air (60 kts +) and when we got back to port we noticed that the starboard U bolt that the backstay is attached to had pulled the fiberglass away from the hull and had factured the gel coat around it. Has anyone had a similar incident and how did you fix it? The attachment of both the deck and of the U bolt seam very weak to me and in need of brace, apart from the fix I'll need to perform! Any help in this area would be appreciated. Scrimshaw.
Rod Leonard
Back stays
I think there has been some articles about this. I checked mine when I bought the boat this spring. They reinforced mine and put bigger U bolts in place. Looks like it was done at the factory.
G
Gene Jones
backstay support
Last year Mr. Cohen a H45 owner posted a note about this. I check Fairwind and found that my boat (a 1988 model) did have the area reinforce with plastic wedges. I am planning of adding more support for my peace of mind.
G
Greg Cramer
Backstay - '86 Legend
My Legend 45 (1986) has not shown signs of a problem yet but I have been nervous for some time. I will probably reinforce the area and install longer U-bolts.
