I was able to figure out the sink thanks to some awesome help from here, but I need a little help with the drain? The water doesn't go away? Is that normal to have water stay in the sink? If not do I need to open some hidden valve to allow drain to work? I did find a hidden valve to allow the sink to work
now if I can just get the sink to drain... I took a plunger to it, and the water will flow after I give it a couple of pushes, but no matter how much I plunge... not sure of the spelling... I pull up more water than drains out?
