83 Hunter 34' Shaft & Strut Info
C2L
Mar 11, 2012
9
Hunter 34 Cranes Creek
Does anyone know where I can get information and possibly purchase shaft and strut for a 1983 Hunter 34? Any information such as shaft length and strut type as well as where to purchase these items would be greatly appreciated.
Thanks in advance!!!
Dec 14, 2003
1,433
If you have the Yanmar 3GM30f engine with the Kanzaki KM3-A tranny (2.61), the shaft is 1" . However, be very careful with the shaft length as it may vary ! A few years ago I had to replace the shaft on my 84 H34 and having picked up the specs right here on the site, I went to the prop shop and told them I wanted a 1 inch shaft, conical, 50.75 inches long. I almost got mad when the shop owner flat out refused to do it if I did not bring the old one. He knew what he was talking about ! I took the old one out, and it measured 54 inches. I humbly apologized to him.
So my advice is simple. Take the old one out if you need a new one, and bring it to a good prop and shaft shop in your area. Folks and marinas around you in Cranes Creek should be able to point you in the right direction to find one. Good luck
1,433
Ok thanks for the info and tip! Will follow
No problem, glad to be of some help. If your current shaft is stainless or monel ask the shop if it can be straightened. If bronze, replacement is necessary. Good luck
Dec 8, 2012
3
Hunter 37 cutter REDINGTON SHORES
For the strut contact Stuart Wheeler at http://millersislandprop.com/underwater_hardware/
They have the original strut mold from hunter.
Ciao have a good day
Giorgio
