83 H34 Purchase?
Ted
Greetings All, Hey, I'm considering purchasing an '83 H34... in pretty good shape... "but" has the Westerbeke engine (I think the model is the W21?)... I'm pretty concerned about maintenance on that beast, as it looks like the impeller is aft facing etc... would really appreciate any & all comments & inputs on (1) this model year H34 & (2) your experiences & thoughts on the Westerbeke? Thanx!
Bill Kirch
H34 Purchase
I own one. I just had the impeller replaced this year. The impeller cost $25 and labor was $65. To small of an item to consider when buying. Bill Kirch By the way, my Westerbeke has 2300 hours and runs like a top--never any problems. Remenber the yahama does not have glow plugs for heating the fuel before you start the motor.
N
Nathan Arneson
Good Engine!
Also have a 83 Hunter 34' with a Westerbeke 21...Have had no major problems at all...good service advice is available from local dealers (see Westerbeke website)...Only bad thing is there is only a technical manual for the engine...no easy to read service manual...not that big a deal though...just reads like stereo instructions Nathan Arneson utband00@aol.com
C
Clyde Lichtenwalner
Westerbeke
We bought our H-34 new in 1982, and when delivered in the spring of 1983 had a choice of a boat with a Westerbeke or one with a Yanmar. I chose the Westerbeke for several reasons. 1) Glo plugs for pre-heating the engine before starts. This engine starts on the first turn in the coldest weather we see on the Chesapeake. Last weekend while the C&C across from my slip ground (same vintage, but engine unknown) through several attempts before it reluctently caught and ran; I preheated for 10 seconds and started right up. 2) Electric fuel pump. Loose prime on the Yanmar, and it won't start until you do the fuel system bleed drill. I owned a Yanmar and it caused grief several times for that reason. Imagine bouncing around in rough weather and having the fuel system suck up some air causing the engine to stall. Been there, done that. This is simply not an issue with the Westerbeke. After changing fuel filters just turn the key and it starts. In the Hunter 34 installation, we discovered that the engine will continue running even if the electric fuel pump is disabled. You get the best of all worlds for fuel system reliability. Yes, the impeller is a pain. You must remove the pump to replace it. That means removing the alternator and removing 4 bolts from the pump. This unhandy, but there is no other way. It is a real pain to reach the bolts to remove the cover, and ispection is accomplished with a mirror. On the other hand, I have always been able to choose the time and place to inspect and replace the impeller. On my boat the pump leaked and was replaced by a new design from Westerbeke. Access is no better. My engine is approaching 1500 hours. I have replaced the impeller twice, the raw water pump once, and the exhaust elbow. Except for the elbow, reloaced by a professional, I have maintained the engine myself. It still runs like a champ.
Doug
H34 Westerbeke
I bought an '83 new (hull #9) and owned it for 16 years. The W21 is a very good engine. I cut and installed an access port in the quarter berth to allow access to the impeller housing which solved the replacement problem. I replaced the impeller 4 or 5 times and the exhaust elbow twice. Other than that, no problems. The self bleeding fuel system is a real plus. The H34 is a great boat. The '83 model had the black deck mounted mast step which apparently prevented the mast post compression problems which plagued later models. Sailing characteristics were she was fast, a little tender (shoal draft), and with the tall mast a 135 genoa would be the sail of choice (the 150 needs to be reefed in the mid teens). Good luck. Doug s/v Tenacious h376
