Read all the posts from a search on this unattractive task. From what I gather, there are two possibilities. (1) Remove the cutlass bearing and apparently that allows enough play to slide the shaft by the rudder/skeg. Or does it? (2) After the prop is removed, elevate the drivetrain and pull the shaft out the front. Unfortunately, I'm not visualizing how the latter works.
1. First, what are the dimensions of the cutlass bearing?
2. Is it just the rear of the engine/trans that is elevated, or does the entire engine/trans need to be hoisted?
3. Once the engine is elevated, I assume the shaft slides forward under the drivetrain and is pulled out from beneath the hatch?
4. There was a suggestion about inflating a ball under the engine to raise it after loosening the rear motor mounts. Wouldn't the ball impede pulling the shaft forward?
5. Finally, the homemade cutlass bearing removal tool. From deep in the archives, someone had the specs and instruction on making it. Could that be provided yet again.
