Due to the near co-location - on the port aft stern under section - of the diesel exhaust thru-hull and the starboard scupper drain thru-hull....engine exhaust will seep up thru the cockpit drain hose into the cockpit and will discolor/deposit onto the white fiberglass about ankle high in the aft area of the cockpit.....
Engines smokes very little so it takes a while but would like to fix a 'flapper' over the scupper drain thru-hull that would block inflow of exhaust but allow outflow of draining water....
Ideas?
Ideas?
