http://www.yachtworld.com/boats/1980/Hunter--2189513/St.-Helens/OR/United-States
So after a deal on another 1980 36 fell through, I came across this one even closer to home!
So I am told that the deck needs to be replaced, there was a quote of $8k to do the job. It sounds a little low to me, what do you all think?
Below are some pictures I took of the cracks where the deck meets the cabin...
Okay, and then there was some water with a slight oily film in the bilge, see below...
I also found some standing water, a very small amount, less that 1/8" deep pooled around the mast at the floor.
So, I am new to sailboats here... my question is, are all of these related? Obviously the deck is failing and likely leaking water into the cabin, but what is your assessment?
I am prepared to make my offer based on replacing the decks and whatever else comes up in the survey, but I am concerned about the amount of moisture inside, will the deck replacement likely remedy this?
Thanks!
Thanks!
