Bob E
Questions arise for Cherubini H27, regarding the topping lift. Several comments, questions come up: Firstly, my particular installation of the topping lift is a permanent "eye" near the top of the mast, a wire to the boom held in place with a "circular spring clip" (not a "c", "e" nor a geesis clip). Removing the topping lift means fussing with this arrangement, always with a prayer that darn clip doesn't decide to go "sproing" into a deep sea dive, and securing the topping lift tends to be an element between fun and creative genius, with my latest using a bungee cords to secure the free end. Recently I was treated, and also see in a couple of older notes, the concept of the topping lift passing over a sheave on the mast top, and being tightened or loosened like any other halyard. Should this be the more normal arrangement for the H27 topping lift? One very thoughtful person put photos of their Hunter 33 reefing and topping lift, which again created more questions. Although the arrangement is not even simlar to mine, part of the discussion was a dutchman seemingly used with the topping lift (which, frankly, confused me).My main boom has two sets of lines coming out near the gooseneck: One with a jam cleat and the other just small diameter sheaves. The PO had a makeshift vang by running a line from small cleat under the main boom, forward thorough a solid "eye loop", and thence to a larger cleat on the mast.In other recent posts on larger Hunters, there is discussion on what other sailors refer to a topping lifts, which either have a "Dutchman", or enter or leave the main boom which leads to more questions, as to what other purpose does the topping lift have other than to support the main boom when the main sail isn't there to do it?Then comes the discussion about using a "BoomKicker" Boom Supports in place of the topping lift. Again a curiosity. If using the BoomKicker, is there enough adjustment and function that a when the boom is in the upper reefed position (more / less about a foot higher than the normal "down" sailing position)? If this sounds strange, let me explain what I have been led to understand. ThIS cherubini H27 has an upper and locked position on the mast, which I have been given to understand is for the reefed position. The unlocked and lower position, is for using the "vang" function to adjust as necessary (unlocked) position.Thanks,Bob Es/v Second NatureSalem, MA
