77 Hunter 27 replacement windows
Randy Sandell
The windows need replacing in my 77 hunter 27 and I need some info on where to look for them. I also could use some instructions on how to use the Homestrand model 209 alcohol stove.
Dec 2, 1999
15,184
Opening ports or fixed!
Randy: I assume that you have the fixed port lights on your model? If that is the case, then you can try Mark Plastics in Southern Cal. You can contact Mark at Mark Plastics 909/735-7705. If you have opening ports, then they are probably Grays which is now Bomar/Gray and they are available at Pompanette or Thrifty Mariner.
