Enjoy Your Day
Art is right on with his explanation of the stability factor (as I like to call it). The H25 is a very stable boat, somewhat tender until she gets around 15 degrees of heel, then she hardens up. Last weekend, I had mine out on the Lake in 10 to 15 knots of wind with gusts in excess of 20. Full sails with a 155 Genoa. While close reaching she was typically 15 to 20 degrees of heel with an occasional 30 degrees. There were a few instances where I eased the main to prevent a possible round up. Waves were notable but of no problem. To me, the H25 is a very stable and, when she needs to be, a very forgiving boat. Do not get me wrong, even though I consider the boat to be stable, it will round up. This is a saving grace, however; frightening the first time it happens but, as long as she rounds to windward, no problem. Once, you know what it feels like, you can avoid it by easing the main, or by letting the sheets go. What does it feel like ..... well, first of all you are on a pretty good heel, the tiller starts to get really stiff (hard to move) and, if you have not done something at this point, it will suddenly loosen up (the rudder has literally come out of the water) and you will be turning, quite rapidly, into the wind. I race on a 30 Catalina and have rounded up on numerous occassions. I would describe this round up as violent. The H25 is not nearly so violent ..... it is just saving itself because you are not. Hope this helps ..... enjoy your boat, it is a good one.
