David E
'77-'83 Hunter 33 De-laminationDuring my search to buy a Hunter 33 I have discovered de-lamination in the side deck area amidships near the chain-plates to be a common occurrence. This de-lamination is evidenced by the crackling noise resulting from walking on this area. Will any body tell me what if any core material is used in this area?I understand that de-lamination repairs are done by drilling holes through the top layer of lay-up and through the core material to the top of the underside lay-up. Then the holes are filled with epoxy to form a dowel between the surfaces. Are these epoxy dowel repairs adequate? I have read in this form that de-lamination can be wet or dry. If the de-lamination amidships is dry, would this type de-lam in this area be the result of structural stress? And again, are epoxy dowel repairs adequate? Can anyone help me understand more of this type of repair in the area described? Thanks for any info offered.David
