I had hijacked another thread to share my rudder story:
And having been away awhile, I’ve found it difficult to find my posts. Maybe I should consolidate as others have.
My list of projects is pretty extensive. I’ve owned the boat since 1/2016 and have never sailed her. Motored a bit mastless as we replaced the rotten bunks:
I am just starting to sand the rudder I started a couple years ago (link above goes to the start):
Projects:
Gelcoat cracks below water line
Chainplate eyebolt upgrade
Stem fitting reinforcement kit
Starboard bulkhead reinforcement
Cracked liner at starboard bulkhead
Port lite gaskets
Finish work to install motor mount
Trailer lights & wiring
Finished projects:
Acquired motor ‘99 5hp 4S Evinrude
Replaced impeller & fluids
Built wood motor stand
Replaced table leg pivot pin
Stabilized and refinished tiller
Replaced keel lock bolt
Filled 10 motor mount holes
Built battery box
Bought and installed battery
Repaired wiring
Replaced bow light assembly
Reinforced keel winch mount surface
Replaced keel winch
Replaced trailer bunks
Questions about the rudder
Things are moving along with my rudder rehab. I finally got the guts up to mix up the epoxy, and patch the damage. I'm not sure I can say it went well, but it got done. I learned a lot and it got done. So, today, I mixed up gel coat and put three coats on one side of the rudder. I think it...
forums.sailboatowners.com
Projects:
Port lite gaskets
Finished projects:
Built battery box
Repaired wiring
Replaced keel winch
