7.3 head 1979
Sep 17, 2017
16
Pearson 28-2 washington nc
This responds to an oooooold posting that I'm inexplicably locked out of, so can't respond there.
I originally had a porta-potti with pump-out and vent. I plumbed in a 20 gal plastic tank in the first locker under the v-berth and have never regretted it.
I did as much plumbing as possible with residential PVC drain pipes. The marina pump-out is easy and when I go 3km offshore I can hand-pump the tank.
Dec 2, 1997
9,010
- - LIttle Rock
...and when I go 3km offshore I can hand-pump the tank.
You need be at least 3 miles offshore, which would be almost 5 km...3km is less than 2 miles.
--Peggie
"If you can't explain it to a six year old, you don't completely understand it yourself." --Albert Einstein
