I sail an inherited '60s Widgeon, and I recently capsized it for the first time. I knew that in general small dinghies can be righted by jumping on the centerboard or keel while hauling on a line attached to the mast. However, this quickly proved impossible as the boat didn't stay level in the water--the stern sank until the boat was vertical, nose poking out of 10' of water. Needless to say we weren't able to right it without assistance.
My question is twofold: First, has anyone else had experience swamping/capsizing a widgeon? Were you able to right it without assistance, and if so how?
My second question is more specific. The wood transom on the boat is deteriorating, and the fiberglass in the cockpit is beginning to pull away from the rotting wood. I can hear and feel air escaping through this gap when I sit on the stern compartment, and I suspect that this might have something to do with the fact that the boat sank stern first. Does this sound plausible? I hope to replace the transom sooner rather than later, but would like to give it a band-aid fix for the present if I can as I'm away from home for the summer and have been sailing regularly.
Also, much of the Styrofoam under the gunwales has either deteriorated or fallen out completely. I wondered how much help it would have been in the event of a total capsize; the failure of the stern compartment as ballast seemed more likely to cause it to sink, but I'm still not sure.
I'll have pictures posted tomorrow. Thanks for your help!
