54 foot mast and the Okeechobee Waterway
Aug 28, 2007
127
Hunter 33.5 Northern Neck, VA
Can a sailboat with a 54 foot mast cruise the Okeechobee Waterway. I know there is a 49 foot bridge that one will need to tip the boat but what about the rest of the route? Will I need to demast? I have a 33.5 hunter. Thanks in advance for any help on this topic.
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
I'm sure you've looked at:
http://www.offshoreblue.com/cruising/okeechobee-bridges.php
One of the biggest hurdles for sailboats using the Okeechobee Waterway is the Port Mayaca RR Bridges’ 49’± vertical clearance. Unfortunately, with this portion of the waterway being non-tidal that means there is no waiting for low water to squeeze a possible few extra feet under the bridge.
However, lower water levels may often present an opportunity! Any time that the St. Lucie Canal is below its normal pool level of 14.5’; the result will be an equal increase in vertical clearances at all affected bridges.
Okeechobee Limbo
Still not enough? If your MHH is still a little too much to make it under the bridge, all is not lost. Bring in the "Okeechobee Limbo." Simply put, a crew out of the Indiantown Marina will meet your boat at the bridge and by use of plastic 50 gallon drums lined up along your rail and filled with water, list your vessel enough to pass under the Port Mayaca RR Bridge. Once through, the drums are emptied and removed from your boat and you are on your way. The whole process generally takes less than an hour.
While this method will not work on some broad beamed vessels, the majority of sailboats can benefit with a MHH reduction of up to 5 or 6 feet. With every boat having their own characteristics, results differ. For more information or reservations, contact the Indiantown Marina to discuss your requirements.
https://www.sailmagazine.com/cruising/a-boat-delivery-via-the-okeechobee-waterway
Likes: Golden Roo
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
When I checked on this in April, the fee was $250, and the gentleman said weekends work best. (I think he works a regular day job.)
I don't have any contact info, but if you call the Indiantown Marina, the will give you the guy's phone number. (He does not work for the marina.)
Jan 4, 2010
1,037
Farr 30 San Francisco
Have you seen the balls video? It is hard to search for but well worth watching. Oh actually easy "boat balls"
SG
Feb 11, 2017
1,670
The clearance you need is really to the instruments, anchor/Nat lights, antenna.
If you are really 54’, a 49’ bridge might be a bit much?
Obviously talking to the guy in Indianhead is a start — but “oh shit!!!” might cramp your trip and wallet.
Gunni
Mar 16, 2010
5,937
Isn’t the Okeechobee full of algae, grass and dead animals? I had a crew member develop extreme respiratory stress from breathing red tide vapor. Run the Hawk Channel and through the keys. Stay as far off the SW coast as possible.
