4lb. Tank
RNC725
51
Hunter 326 Lake Thurmond, GA
Still getting used to the convenience of having LPG vs. the alcohol stove on my old LP 1967 Cal 30. Would like to get a second tank our Hunter 326 but having bit of trouble locating one. Also I am wondering will there be an issue and getting my existing 4 lb tank filled as it is a 2002 model. We've had the boat now since late August and it really appears to be fuel efficient as compared to our old alcohol stove.
Many thanks
Jan 4, 2013
285
Catalina 270 Rochester, NY
I bought a new 4 lb tank this year at Home Depot. They had to order it so I had to wait a day.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
What are the required dimensions? I love the 1960's Cal 30! Great sailing boat. Vertical or horizontal? Steel or aluminum?
We have a 4.5 gallon, steel, vertical, 12-3/16 x 18 inches.
Mar 20, 2004
1,746
Walmart online also has them...but if SBO can get it, use them!
you only get 12 years before a reinspection is required, so you probably can't get your current tank refilled
JohnAC
Nov 16, 2018
14
Hunter 42 Passage New Bern
You can have the tank re-certified, its good for 5 years, it just a visual inspection. Find a propane distributor or even some barbecue places can do the inspection. Just had 2 tanks done for $10 each.
RNC725
51
Our Cal was a great boat to cruise, fast too. Is this the Dave that has been helping us outfit our 2002 Hunter 356 -- new cockpit cushions, companionway doors, led lights etc? Hats off to you and all the SBO staff!
Dec 28, 2015
1,911
If it doesn't have a OPD valve a propane distributor like Suburban Propane can install one and inspect it all at once.
