Use genset twice a day
I use my inverter for many relatively low current and/or short time demand items. Microwave, 110 volt lighting, computer, food mixer, blender etc. are all great uses as they do not over tax the batteries. The freezer and frig on our 460 will run from the inverter, however, the demands is very large. I have found on sails, albeit one day or one week, starting with cold boxes, I can go easily twelve hours with only about a four degree change in temp if I don't open the box too often. If overnighting, I run the genset 3/4 to 1 hour to fully recharge the holding plates and batteries should they have been drained from other use after dinner. In the morning, or 12 hours hence, I again recharge the holding plates for 3/4 of an hour after breakfast. This has worked well for me for many multiday sails. I use this system when cruising without any loss of frozen foods and good temps in the frig at all times. Hopes this helps.Don GuggenheimS/V OZ
