41 DS anchor locker hatch
Jun 3, 2004
241
Hunter 41 DS Punta Gorda, Fl
I am new to my 2005 41 DS. I was planning on moving the current Delta anchor over to become my secondary anchor. I have a new Ronca 54 ready to go on to the roller but when I tried to close the anchor hatch it hits the Delta anchor. The hump in the hatch is aligned only to for the primary anchor. I am hoping someone has done some modification that I can follow so I can place the secondary anchor and close the anchor locker hatch. Pictures would be great thanks :confused:confused:
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
Good luck with your new boat. I love mine. I agree having two anchors ready to go would be great. Aside from the hump issue, will a second anchor bind on the first? By the way, I use a Mantus 45 which works great.
Jun 3, 2004
241
good question on my old 376 the secondary anchor was off set a lot more than the primary anchor. I wondering if this roller is not off set enough.
Do you only have the one anchor
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
My 2004 44DS is the same way, I never understood why Hunter would go to the expense of putting on a double bow roller and then design the anchor locker hatch to be incompatible with it.
Jun 3, 2004
241
I have a fiberglass person coming to look at it Tuesday. I am thinking about changing the hump to fit two. But first I need to see if two anchors and live together on the roller seems the off set is not very far apart. If they will I think I can expand the hump to handle two.
