Rich Stidger
I have a 1997 model and I think the 1996 production year also had the Volvo MD22L-B engine.There is very little clearance between the top of the oil filler tube and the bottom of the drawer in the engine compartment.How is the best way to add oil after a change? A quart container can only be filled half-way in order not to spill the oil all over, and a long tube leading to a funnel outside the compartment almost takes two people to manage and the oil runs very slowly.I've looked for a hand pump that I can simply pump the oil into the oil filler, but I've not found one.How do all of you do it?
