Patrick Magers
Dear Rick:For clarification purposes, the single line system was changed to a two line system by placing a downhaul line for each reef point on the main luff which was then cleated off at the mast when reefed. The original reef line was then only attached to the clew, running thru the boom and back to the cockpit. The original setup reguired the reef line to exit the boom and attach to the luff reef point and down to base of the mast and back to the cockpit. I personally found the two line system very easy to manage with no resistence in in the reefing process with a flatter sail when reefed. I did not cut or alter the original reef lines. To restore the single line system would only require the two downhauls to be removed and the reef lines to be again attached to the reef points on the luff which should take about 5 to 10 minutes of labor. You should try both systems to see which one works best for you. From the original owner, Patrick
