Radar Cable in 40.5 mast
Just did same thing, routing a Furuno 1622 cable through the PVC mast conduit in my 40.5. I chose the Furuno 16 mile radar because the size of the cable is fairly small (about 3/8 in.). Mast must be down. My mast has two PVC tubes, and neither are very full for their size, so space in the PVC conduit was not the problem. Drill about a 3/4in. hole in LE of the mast at the proper spot. With care and a focused light beam one can see the PVC pipe through the hole. I then used a very long 1/2 in. drill bit through the mast access hole and with care and feel one can drill a hole in the PVC pipe. Then with a long plumbers snake, it's possible with a lot of patience to push the snake even with the hole in the PVC pipe, fish it out with a hooked coat hanger, and get it through the mast access hole. From there, pull through a stout string or wire as a messenger. Now, the hard part, which is to pull the radome end of the cable from the bottom of the mast through the mast access hole. This was impossible without taking apart the 9 pin connector, and eventually destroying the little spring clip connectors. So I cut off all the sockets and finally got the cable routed through and out the access hole. Then I had to crimp on new sockets that I ordered from a Furuno (dealer), with a proper crimp tool from NAPA. Be sure to install the sockets in the correct slots in the connector. It was a real bear, but it can be done. I suspect other brand of radar cables might be harder.
