You have a point, In my area however, a shortened mast is a very good selling point. My cruising range would go from 20 to 150 miles.There will be buyers including me that wouldn't look at it with a shortened mast....something to think about
OK Bill, I have seen pictures of that done.tip the boat. Lister bag (google it) hung from the main halyard will heel the boat enough to get under the bridge, and you will be the talk of the town.
after filling the lister bag with water by throwing it over the side haul it up with the halyard. Since it is now really heavy it will heel the boat before it comes out of the water.
The math says you need 28 degrees of heel minimum
What height did you lower the mast to? The boat is at Lighthouse Landing and I have the option to keep it there, hence wanting to pass under the Eggners Ferry bridge and possibly travel south. A lot of the time when I had my 34 on Ky Lake I wound up having to reef. Did you take your boat from GTB to your current dock? Would like to spend the winter making such a trip.The PO of our 376 changed the mast to masthead from fractional. Marty at lighthouse landing did it . When I bought it performance was weak but the sails were blown out. I recently bought new sails with a deep roach, easily recovering all the lost sail area. Performance is excellent, handling is improved, and the shorter mast lets me go places others can't.
Talked with Marty and the new bridge will be 65'. With a 62'9" mast height it would be close but doable. Maybe I list a little. Thanks for all the input fellas.Come on down. Likely have to drop mast.
The best thing about the boat is the mast height & fractional rig.Talked with Marty and the new bridge will be 65'. With a 62'9" mast height it would be close but doable. Maybe I list a little. Thanks for all the input fellas.
