SIMPLE WAY
HI RICK. I LIKE YOU HAVE TWO BATTERY BANKS. ONE, THE HEAVIEST, STRONGEST ONE IS USED FOR THE HOUSE,IE, LIGHTS, REFRIG, RADIO, TV, ETC. THE OTHER BANK IS KEPT IN RESERVE FOR STARTING. SIMPLY PUT YOUR BATTERY SWITCH ON THE BANK USED FOR THE HOUSE AND THE STARTING BANK IS EFFECTIVELY ISOLATED. RUN THE ENGINE EVERYDAY TO CHARGE AND MAKE HOT WATER AND YOU ARE IN BUISNESS. THE TRICK IS TO KNOW HOW LONG AND AT WHAT RPM TO RUN THE ENGINE. THIS YOU WILL LEARN FROM TRIAL AND ERROR.GOOD LUCK.PS. WHEN ARE YOU GOING.
