When you run rv antifreeze through the system do you leave it in or do you open the drain plug on the heat exchanger after
I drain it. That way I have less propylene glycol in the system on startup in spring. The less of it dumped in the water the better.
Never known anyone here with rust issues, but they all periodically acid flush their systems as described in the atomic 4 maintenance manual.
Ethylene glycol is used in automobiles/trucks/and the closed loop portion of marine engines due to it's superior thermal and friction properties compared to propylene glycol.
Don't ever use pure ethylene glycol for freeze protection. Always use mixed. Contrary to what you may assume, once you get past a 60 ethylene /40 water mix, the freeze point goes up.
Pure ethylene glycol freezes at 9F/-12C
For comparison, pure propylene glycol freezes at well below -60. So
Keep in mind that both are available in 50/50 premix and pure/concentrated. I always buy pure. It is cheaper to mix yourself and we use a 60/40 ethylene mix here in vehicles, due to the extreme cold winters.
@Maine Sail method works great BTW. A sight refractometer is available for under $20 on amazon. Best way to test your vehicles too.
One owner here uses air to purge any water from his engine. Our winters hit - 40 and he has never had a problem in decades. I have yet to see how he does it.
I use a shopvac to suck all the water out of potable water lines.
Makes me wonder about doing that for the engine.
