3YM PresurePlates??
BruceK
Jul 26, 2005
74
Hunter 33 Portland, ME
My yard has spent hours tracking down a "squeel" like sound when under forward load at 22k rpm only. We have been though all the possibles and long shots like belts, water pump, alternator, cutlass. Engine alone is just fine. The yard mechanic and his boss recken its pressure plates...I have warranty time...engine only 200hrs. Ideas?
Nov 6, 2006
10,103
Correct amount and type lubricant in the transmission? Pressure plate transmission or cone clutch?
7,462
Alden 50 Sarasota, Florida
I assume the 22k rpm is a typo - 22oo rpm? Mechanics who work on transmissions in boats tell me that the pressure plate will make a clatter sound but only at low rpm (as when shifting between neutral and gear) so I suspect your problem lies elsewhere.
BruceK
Jul 26, 2005
74
2200 rpm...and it is not a clatter so I am more than a bit concerned with the yard expertise....
Nov 6, 2006
10,103
interesting.. may be related to an alignment problem that causes a prop shaft resonance at that RPM..
7,462
always follow your instinct. It's impossible to accurately diagnose the problem via the internet but I can be pretty certain the yard folks where you are don't know much about transmissions
