As anyone with experience using this product knows it is best for something you never expect to remove. It has its uses, though, but often times an entire tube isn't necessary, and surplus is often is wasted. I did a job today with a tube I opened in March 2010. I seal the ends with aluminum adhesive tape and refrigerate it between uses, and the nozzle can be cleaned out with acetone while the adhesive is still wet.
