3gmf yanmar diesel engine oil and capacity specs
776
Hunter 33.5 Elbow, Saskatchwen, Can.
Welcome to the best hunter forum.
If you go to the boat info tab then select downloads and general info you will find the info you are looking for and so much more.
The yanmar 3gm info is near the bottom of the page
Dec 2, 1999
15,184
Be careful when refilling the engine. I do not believe that the engine capacity takes into account the tilt of the engine. I would only use about 3/4 of the total capacity and then check it. As I remember our 2GM only took about 1.8 qts.
You may also have some oil left in the pan after the removal process.
