I have a 1983 Hunter 34, Yanmar 3GMF, with a Racor fuel filter. I had no problems with fuel/engine run UNTIL I pulled the old (can't remember last time I changed it) filter, and put in a new one in earlier this week.
I did not remember (or never realized) that I should have cut off tank fuel flow first, and made sure I topped off the bowl before putting the cover back on. :naughty:
Yesterday, I started the engine, got 4 of 5 dock lines off and was backing when she died...
After much noodling, and some forum search here, I did these things:
1. Filled the Racor bowl and the smaller fuel/filter bowl with diesel fuel. Tried to pump the little and well hidden lever to try to get fuel to flow up to the injector nut with I opened... nothing.
2. Opened the nut at the small fuel bowl (on the side) because there is no way to get a screw driver tip on the bleed screw on top because the fuel line runs 1/4 of the way over the surface area and couldn't get a good tip/screw line-up.
3. Tried cranking engine interimittently to try to get some fuel flowing - nothing.
4. Bought an outboard squeezy ball from West Marine, and installed that at the Racor... Squeezed it (injector nut still open) and nothing flowing out... except out of the squeeze ball.
5. Opened up the nut at the small filter again, and fuel game out.
Sooooo, I'm getting fuel to the small fuel filter, but not beyond... that I can tell. "Something" is restricting flow, right? I thought that maybe I should go back to the boat and try to:
1. Push the small primer lever in the down position while at the same time squeezing the squeeze ball... Does it open up a diaphram that's otherwise closed in the "up" position (not an engineer, but it's what my brain came up with).
2. Does the throttle position matter? It's in the up/neutral position.
3. Since the small fuel filter is very clean - I'm doubting that anything got to the up-stream side of the line heading toward the injector... but I guess that could be possible - don't know that I dare messin' with that!
4. Could the small pump have coincidentally failed in addition to my BAD on the fuel filter change?
I'd appreciate any suggestions before I call for a mechanic... I really do try to keep things running myself - this time I shot myself in the foot though... Thanks in advance, Dave.
