D. Grosz
I have a '92 model that has a recurring overheating--at least apparent overheating--problem at full throttle. First, this engine has been babied with frequent oil & filter changes (Chevron Delo 30w & Yanmar filter), the exhaust elbow is two years old, and the cooling system has been flushed regularly.Under normal conditions I run the engine at 2,800-3,000 RPM, and there is no problem. Occasionally I run it to 3,200 again with no problem. At full throttle I get 3,400 rpm and after 5 minutes (with the engine already at op temp) the overheating light and buzzer come on. At this point I throttle down to about 2,000 and the buzzer goes out after 30 secoonds and the engine runs fine. This is the second time its happened.Any suggestions?
